Could/Would you go smaller?
Old 08-02-05, 12:57 AM
Wigalo
Wigalo's Avatar
Default Could/Would you go smaller?
Ok guys this may sound goofy, but I have an 06 GS430 and the standard setup is 18 x 8.0-in alloy wheels with 245/40ZR18 tires.
I would like to place aftermarket rims on it. My problem is I don't want to go any larger than 18's for several reasons, but there are a limited amount of wheels that I like that come that small.
I found a set that look perfect, however the largest width they come in 18" is 7.5. My goal is to make the rims look more aggressive than stock by coming out closer to the fenders.
With enough offset, would these work, or would decreasing the wheel width by the .5" not make any sense. If it's plausible, what approx offset would the rim need to be to make the look as aggressive as possible without any fender rolling.
thanks guys.
Old 08-02-05, 09:25 AM
Neo
The One
Neo's Avatar
Well, if you want it to be closer to the fender, reducing the rim width will not help. I'd rather not go smaller. Aren't there 18x8.5 rims out there that are similar to the ones you want? Also remember, there is more space in the rear. A size that may be "flushed" in the front will not be in the rear. This is partly why many go with a staggered setup.
Old 08-02-05, 09:46 AM
Lexusfreak
Lexusfreak's Avatar
Cool
Why not be patient a while longer as I'm sure more choices will be available in the next 6 months or so. If you get something now, you might kick yourself down the road. Just my 2 cents.
Old 08-02-05, 10:03 AM
RobSoVIP
RobSoVIP's Avatar
there are tons of nice 18's that you can get in 8.0, 8.5, and 9.5 widths. How much are you willing to spend? What look are you going for (executive, sporty, etc).
Rob
Old 08-02-05, 02:52 PM
J.P.
J.P.'s Avatar
thanks guys.
It's going into Aug now, if you have a winter season then wait until spring.
Old 08-02-05, 05:44 PM
Wigalo
Wigalo's Avatar
here's the look;
the problem is, that it's hard to find this style in anything smaller tht 19.
Jmonsini57
11-02-13 05:09 PM
adammb
06-30-10 10:40 AM
MadTweaked
IS - 1st Gen (2001-2005)
20
11-09-07 06:18 PM
Lexus Boy
GS - 1st Gen (1993-1997)
29
10-18-07 09:27 PM
gwu128
04-07-02 09:26 AM
Quick Reply: Could/Would you go smaller?
