Are these good offsets?
Hi guys, I'm seriously considering a set of wheels being sold locally but was wandering if i can get opinions on the following specs.
Width: (F) 8.5J (R) 9.5J
Offset: (F) 39mm (R) 45mm
is this going to work? any fender mods or spacers needed?
99 GS300 stock calipers with Tein CS.
when referencing rominl's write up:
http://www.lexusgonewild.com/article...lFitment.shtml
the closest specs i can get is
19x8.5 +38 19x9.5 +38 "conservative "
the 1mm difference in front shouldn't be a problem. my concern is in the rear and whether the difference between +38 and +45 will be a problem.
Please advise.
Thanks Guys
Please advise.
Thanks Guys
according to my VIP Car magazine most GS's have offsets around +30 front and rear with eiter 8.5F and 9.5R or 9F and 10R for width. But asome are using 19 9.5 +40 rears and they look decent. You will most likely have to add spacers though, at least in the rear.
Originally Posted by Neo
They are conservative offsets and should fit without any fender mods.
How's about the inner? do you think it will rub on the inside?
Thanks man.
exclusive matchup
those are good consevative numbers. no need to worry about inside, not even close
and i would definitely be careful with numbers in vip car mags. a lot of times their numbers, you won't be able to fit unless you do a lot of fender mods and put on some pretty bad negative cambers
