Should I get staggered wheels or not?
Originally Posted by ajayssc40093
One of my commandments for the Lex is staggered wheels. I've wasted money on same size rims only to be drawn to the staggered setup, sooooo sexy!
Originally Posted by ifilrx
Good point..that was my other worry...
staggerd is all for looks,
but if ur not gona spend good money on wheels then dont waste ur time.....
personally im a track driver and blance is the key so i went 9.5 all around....(on my 240)
the sc will be 10" all around when i get to doing the wheels
Bumping an older thread so I don't get yelled at for starting my own...
My Dad and our neighbor (who is a mechanic, and his word is like a commandment from God to my Dad) both reccomend I stick with a non-staggered combo. Their reasoning is that the tires can't be rotated, and that the front will wear down in half the time of the rears.
Is the wearing issue true? Obviously they can't be rotated, but I hadn't heard about the wearing.
I had considered running TT wheels because of price (where can I get OEM quality wheels for >$600 besides TTs?), looks, and the aggressive fitment (conservative but still looks great from the rear).
Originally Posted by morris
my experience is that the drive wheels wear faster. This means if you have an SC400 then the rear tires will wear out faster than the fronts. So the wear issue is true and rotating may get you a bit more mileage on a set of tires.
How much can I expect a normal, daily drive type tire (no need for super sticky performers) on staggered sizing to last? Compared to a normal setup?
My advice would be to go with the TT set-up first so you have a good idea about how long you can drive before you need to replace tires, everyone's driving style is different so I can't say how long tires will last you.
...and 17" tires are much cheaper than 19's
-M.
