Stepped or reversed lips, which do you like?
Originally Posted by lnguyenh
Still I don't get the "reversed" one, why is it called "reversed"? Thanks.
Reverse drop center wheels have the the dropped part closer to the back side of the wheel. This keeps the rim full diameter at the face side allowing a larger disk (spokes). Tires are mounted from the rear side of the wheel.
Originally Posted by cyclemax
It's called "reversed" b/c it has a "reversed drop center". The drop center is the part of the rim that drops in to allow bead clearance when you mount a tire. The standard set up is to have that on the outer part of the rim so you can mount the tire from the front of the wheel.
Originally Posted by BUSTN
I am really digging the 2 pc stepped lip with extereme fit forging from Iforged.I don't really see many or any at all with stepped lips around here?Why?
In my opinion it all depends on the style of the wheel. In most examples I have seen, the stepped wheels give me the impression of a smaller wheel, while the reversed lip seems larger. I think they look equally as nice when done right. I will say this imho a reversed lip is like Halle Berry in cat woman, no matter how dirty or muddy they get they will still be sexy
Originally Posted by SSK0771
You sure you want to get Iforged even with all that horror stories of Extreamly BAD Customer Service and Clear Coats peeling off?
We wont have that problem now with D2Autosport. He takes care of everything with no hassle on the customers end. Never heard of the clearcoat issue. If it was peeling off the lip that is understandable and the reason most people dont have clear put on the lips
yuji's_gs_
Wheels, Tires & Brakes Forum
29
01-25-06 01:54 PM
