Tire Pressure
Old 10-03-05, 10:00 AM
ted920
ted920's Avatar
Default Tire Pressure
Fellas:
I have 20X8.5 and 20X9.5 3-piece wheels and I am running 36 PSI in front and 38 in rear.
What PSI should I be running?
The tires have a MAX PSI of 52 on them.
I know a lot of guys with regular 16s etc run 32 psi or so.
I've never been really clear on what PSI I shoul dhave and what is too much and the downsides of going to high.
BTW, on dips, I tend to bottom out on front driver side. Might this b/c PSI is too low?
Thanks for feedback.
T
Old 10-03-05, 02:38 PM
rominl
exclusive matchup
rominl's Avatar
to be safe i would run around 40psi for more protection on the rim
and what do you mean bottom out? the car hits the gnd?
Old 10-03-05, 02:52 PM
D2-AUTOSPORT
Former Sponsor
D2-AUTOSPORT's Avatar
Same here, I recommend 40-42 to all of our clients, the ride is a bit stiffer but I can persoanally say that iFORGED wheels are nearly indestructable at that PSI, and I have hit some SERIOUS POTHOLES in NYC! (The kind where you think your whole car disappeared down the damn pothole! LOL)
Old 10-03-05, 03:54 PM
aloha08isf
aloha08isf's Avatar
my normal is around 42-44 psi....since your on low pro...I would suggest at least 40
Old 10-03-05, 04:46 PM
rominl
exclusive matchup
rominl's Avatar
wow damn cody, you got a pretty "stiff" back there!
just keep in mind running too much also isn't a good thing, coz' the middle of the tire will be "over infated" and you will actually get more of a middle wear
Old 10-04-05, 07:56 AM
ted920
ted920's Avatar
Fellas:
Many thanks for the info.
You guys are very knowledgeable and I appreciate your input.
I was way low and will get up to 40-42 PSI today.
Ted
Old 10-04-05, 07:53 PM
chuckb
chuckb's Avatar
I've been running 36psi cold on my 245-40-18s.
ajs
RX - 3rd Gen (2010-2015)
23
05-23-09 04:49 AM
wagomaniac
SC- 1st Gen (1992-2000)
01-26-09 03:11 PM
LCSC
12-06-07 06:09 PM
JustinK101
IS - 1st Gen (2001-2005)
02-18-04 09:02 PM
LXOGOOD
06-29-02 10:48 PM
Quick Reply: Tire Pressure
