Wheel and Tire Size - Need Help
Old 10-27-05, 03:01 PM
Capirato
Capirato's Avatar
Default Wheel and Tire Size - Need Help
I have a 2001 GS300 that has 215-60-16 tires and wheels.
I have purchased 17" Lexus OEM wheels, 7 1/2 inches wide.
The calculator comes up for the replacement tires as, 235-50-17.
What have the rest of you done when going to a 17 inch wheel ??
~ Cap
Old 10-27-05, 05:11 PM
blacksc400
Car Chat Moderator
blacksc400's Avatar
THE CORRECT SIZE IS 235/45/17 ON FACTORY gs WHEELS.
Old 10-27-05, 05:21 PM
chuckb
chuckb's Avatar
that's for the 2nd gen 17x8 wheels. he has 3rd gen 17s.
I think 235/45/17 should still be fine though.
Old 10-27-05, 05:38 PM
Capirato
Capirato's Avatar
Default Tire Size
I've read that it is best to stay within 3% difference in the diameter of the tires. Otherwise, risk brake failure.
The 235-55-17 you mention, is 3.76% difference.
The 235-50-17 is 0.39% difference.
Thanks all for your replies. I'm trying to get a consensus before making a choice.
~ Cap
Old 10-27-05, 10:08 PM
Neo
The One
Neo's Avatar
The OEM 2GS 17x8.0 runs with 235/45/17 tires.
The OEM 3GS 17x7.5 runs with 225/50/17 tires.
They are both close enough to eachother that you can just take your pic. The 3GS spec has less contact patch but gives more sidewall. Pick your poison.
Old 10-28-05, 11:19 PM
Capirato
Capirato's Avatar
Default 225-50-17
Neo.....
Thanks for your suggestion.
I think I'm going with 225-50-17, Bridgestone Turanza LSV. They have a good rating at The Tire Rack.
~ Cap
98LS4O0
10-25-18 03:28 AM
GS300916
GS - 1st Gen (1993-1997)
10-11-10 11:20 AM
macz
05-19-08 05:20 PM
olddog
07-15-07 08:15 AM
Intellexual
03-24-05 12:30 AM
Quick Reply: Wheel and Tire Size - Need Help
