Offset question for SC430 with 20" Maya DTS
Hey Rominl or ssk or whoever else has a SC430 can you post some pictures up of your SC with the rims on from a side angle of the rim so I can see how far they stick out and how much farther the fender sticks out than the tire. I am also trying to digure out which offset is best. Looking at the stock rim and tires and using a offset calculator from the stock 18x8 +45 to 20x10.5 +30 said it would stick out an extra 47mm which is 4.7 cm which is about 1.85 inches which seems like too much when measuring from the stock rim, but I could be measuring from the wrong pont. Not sure. Any pictures would be greatly apreciated.
keep in mind your car is not lowered, when it's lowered it's different. though the rear being around 1.8" more outward that sounds about right in my case. the stock setup is just weak.
i don't think i have pics of my car that way, may try to snap some shots this weekend if possible. you know, it's hard when you don't have the car
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
i don't think i have pics of my car that way, may try to snap some shots this weekend if possible. you know, it's hard when you don't have the car![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
Your right when it gets lowered camber makes it go in somewhat but once you get an alignment shouldnt it be in the same position as it is now?
hardly, coz' very quickly you will max out the camber and no way you can bring it to stock spec
but you gotta keep in mind your pretty slammed, meaning your more lowered then most people. For the average person I am guessing they will prob get something around 1"-1.5" drop which should not throw off they camber settings too much. I think you can get it back to stock specs with a 1" drop no problem. Also people could get camber kits. This being said should your offset have been higher if you werent planning to lower it that much or willing to have that high of negative camber.
1" yes, but 1.5" i beieve you will be out of spec already. also, with 1" drop, yes, you might be able to get it back to spec on camber, however, spec is just a "range", you will most likely be in the negative side of the spec.
moreoever, keep in mind that when you hit something and the wheel goes up, it doesn't just go up. it goes up and IN. so thus creating more clearance
and no there is NO camber kits for our cars.
and as far as i know, no matter how you lower the car, the offsets i put up should be safe
and as far as i know, no matter how you lower the car, the offsets i put up should be safe![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
thanks rominl u always got the answers
yeah i would call myself aggressive coz' i am right at the boundary of rubbing already, and tire choice is the key (so you can imagine how marginal it is).
and yes, from pics it might look "ok", but the problem is the fenders. go take a look at your fenders, both front and back. see the fender tabs? that's black tabs, on the gs or other lexus, you can shave them down so your wheels can stick out more to get flush with fenders
however the fender tab on sc430 is actually very "integrated" with the fender lining, so it's very hard to shave it without doing a lot more work on the lining.
hope this is a good explanation
and trust me, with my wheels setup? i am that close from bad rubbing (i rub now coz' i lower the car so much)
