What is the largest tire size you can put on a 18x7.5 rim?
Old 01-02-06, 09:45 AM
Scott1258
Scott1258's Avatar
Default What is the largest tire size you can put on a 18x7.5 rim?
Can I put a 245-40-18 size tire on a 18x17.5 size rim? Or is it just too big?
Old 01-02-06, 07:31 PM
JDMUSCLE
JDMUSCLE's Avatar
235 should fit fine but 245 will make the side wall bulge a little bit!! my friend has 235's in his 7.5 inch rim and they look a little on the bigger side!!
Old 01-02-06, 11:29 PM
vsynergy
vsynergy's Avatar
Ah, the max I'd go would be 225. Any higher than that wouldn't look so pretty.
Old 01-03-06, 09:42 AM
shaolin
shaolin's Avatar
the best for 7.5 is 225. you can put 235, 245, or 255 (i have done it before),if you want but what's the point? it won't handle the way it suppose to be.
sparta3993
03-10-15 08:20 PM
mlor12
02-23-13 09:04 AM
Ruffless
03-23-11 04:03 PM
EyeKutr
09-02-09 06:35 AM
maschronic
RX - 1st Gen (1999-2003)
09-21-06 06:21 PM
Quick Reply: What is the largest tire size you can put on a 18x7.5 rim?
