Pretty sure I know the Answer and I only need this here for tonight...
The black car that GATO posted has flared fenders, so that's not really fair...
Johnny, what width? 8.5 +18? 9.0 +18? This makes a difference.
I stretched my front fenders a little and stuffed a 20x9.5 +40. It was very aggressive with a Yohokama AVS Sport 255/35-20, but now it looks a little weak with a Falken FK-451 255/35-20- the Falkens are stretched. The new wheels will be more aggressive to close the gap.
20x9.5 +40 has the same frontspacing as:
20x9.0 +34
20x8.5 +28
My new set-up will be about 6-8mm more aggressive than the old, which will be about the same as 20x8.5 +20 or +22
My car isn't the lowest GS around and I have the camber adjusters maxed-out as positive as possible (to save the tires) and I still have about -1.7 degrees front & rear. If you spun the camber eccentrics around the other way you could probably get to about -3.0 degrees of camber. Also, if you're running Air, when you slam the car the tires will camber in and tuck at the top.
My vote is that 8.5 +20 or 9.0 +20 is do-able with Air, camber, and a VIP look.
-Bob
20x9.0 +34
20x8.5 +28
-Bob
Bob, I agree that with Air, when dumped, it will camber in and maybe tuck.......
But what about coilovers? let's say you dialed in at a pretty aggressive stance. wouldn't that have the same effect? do you think it can also be achived with coilovers?
also, is a 235/35/19 stretched on a 9 or semi stretched?
Originally Posted by bluelex
You would have to have soo much negative camber it might come full circle and be considered positive again.
b2designs
Club Lexus Vendor Marketplace
436
02-22-18 01:47 PM
slammed_gs
02-02-09 08:35 PM
