would 19x9.5 wheels w/ 235/35/19F & 265/30/19R work on the sc430?
Originally Posted by clubaddict
i think the ps2 tires have a 'inside' and 'outside" section...(with different threadblocks on each side...)(not sure about the other pilot sport models)
so with a staggered setup id pretty much be screwed as far as rotation goes right?
if the tires are directional, then you can't rotate them left to right, but you can do front and back
if the tires are non-directional or asymmetric, then you can rotate them anyway you want
u mean with the 255/35/19 all around right?
it looks like with a staggered setup you cant rotate if the tires are directional...
yes, wheels on my gs400 (staggered with directional tires), i can't rotate anything
Originally Posted by rominl
yeah 255/35/19 or 245/35/19 both sounds good to me.
still weighing wheter to get the tires used or brand new...though id like the benefit of a road hazard warranty since I live in NY(pothole kingdom)...used i could prob find for 25% of the price with half the threadwear gone...
i guess with a all 4 the same setup i can rotate front and back if they are directional...
You think putting spacers in the back will be ok if they arent flush with the rear fenders or you think I may have some issues with handling/reliability?
the wheels are +45 offset and 9.5 wide each front & back, 19" diameter
cars not going to be lowered... i live in ny and its bad enough...
how would this fit?
would I have any rubbing problems whatsoever with a combination of
245/35/19(or 255/35/19) in the front
and
275/30/19(or 285/20/19) in the back?
what about wheel spacers? is there any benefit to using them? pro/cons?
how would this fit?
and
TandR
RC F (2015-present)
21
08-19-20 08:11 PM
ceboyd
04-07-03 02:00 PM
