What to use to roll fenders
Originally Posted by tonydt1g3r
I am wondering what tool you guys use to roll your fender. IE a bat? Lead pipe ect. Also does this crack your paint?
There is a tool that some shops have to do it correctly....I would NOT use a bat. Have it done right
![](http://www.tirerack.com/images/accessories/product_images/medium/fenderlip.jpg)
Rominl the 255/35 rubbing pretty bad.
tried the heat gun this weekend still rubbing
trust me I heat gunned almost everywhere.
Pretty sure its rubbing the top of the fender well. I am either going to have to raise the car up some or get smaller tires
![Crying](https://www.clublexus.com/forums/images/smilies/Peace.gif)
you are rubbing the top of the wheel well, close to the outside right? that's pretty much a problem for all 20s. i rubbed too (and i have 255 as well, but doesn't matter, 245 will still rub, i checked). after rubbing for a while it will rub out part of the fender flaps and you will have less and less rubbing. it's no bigging. i didn't do anything to my fenders, there is a small hole there now. i am not giving up my wheel gap.
if it was a little rubbing it wouldnt be too bad, but when I tap the brakes its rubbing big time not just the top but the back also and it makes a really loud noise. I am thinkin of 245/30/20 which should be drastic enough. I am going to raise my car up a little and see how it looks first since thats cheaper and easier. I even took off the black ruber that covers a metal band that goes around the fender at the edge since it was all rubbed down to the metal. I didnt think that there was going to be such a big problem with these tires. I already rubbed a couple holes
you are rubbing that metal stripe on the fender edge as well?! how come?!
how low is your car? i have zero finger gap, and i only rub when i hit bad dips, and it's only at the top of wheel well
this is weird man. i am just wonder how much would 245 help. we are talking about 4mm difference here
