Question about 20's (that I have) (pic included)
I bought 20's about a week ago, and I ran into 2 problems...... Hopfully someone can help me out on these issues....
1) When I go past 55-60, on the highway the steering wheel starts to raddle badly, someone said I need spacers? What are they? And how much will they cost??
2)My brakes squeek when I try to stop... I do I make them sound normal? Do I need new ones for my new wheels since they are bigger???
Pics :
Pics :
Na u dont need spacers, the tire shop needs to verify that those rims are the correct offset for the car. 2nd, take it to a shop that can balance 20"rims and better. Mine did that also, and the first shop that did it balanced them like they did 15" rims, that's a no no. Took it to a rim shop and they did it with a special machine made for the bigger rims of today. Came out smooth as a baby a@#. Also see if they gave you hub centric spacers, those help also. If none of this work, take them back.
IMO, rims on a stock height (esp. 20's) look nasty - get that **** dropped!
You need hubcentric rings - they center the rim on the wheel hub. For question 2 - change the pads to OEM, clean and grease the slider pins and turn to rotors, the squeeling will stop.
I don't think the rim place I bought it has these balancing tools, not sure..... If they don't is it a good idea to go to a place like SEARS or Pep Boys (big franchises) and have them balance it, or find another local rim shop with the right tools?
Anyone who installs tires should have a machine to balance them as well.
Jonny
If you care about your RIms and Tires than stay away from Sears and Pep Boys
....I would definetely ask around and go to a reputable shop that is known for selling, mounting and balancing larger wheels and tires...
![Thumb Down](https://www.clublexus.com/forums/images/smilies/thumbsdown.gif)
NCLexi250
Suspension and Brakes
04-28-12 06:32 PM
