245/40/18 on a 18x8 5 114.3 w/40 offset fit?
I know a lot you you will say get 20s, but I don't want to loose the stock ride feel.
Will tires 245/40/18 work with a rim that is 18x8 bolt pattern of 5x114.3 and offset of 40 work? I'm assuming I have enough clearance so that if the wheel is flush with fender it shouldn't rub. I think this is an aggressive stance from looking at one of the sticky threads.
