Toyo t1-r's are the sidewalls fatter than the t1-s's
bob
myself and 3 others have the t1r down here and we all had the same feelings.. the inner tread wore faster then any other i had , they scallopped badly on the inside and my bbk would always lock up my tires , they developed a slight pull to one side , this is just my opinion afetr having them for about 8k miles or so , they also let loose in the corners without warning , i have had goodyears , dunlasp, bridegstones and the toyos and so far the toyos i hated
That is surprising Ed. I have had them on my car for nearly 10k miles and the only noticeable wear is on the rear tires. These have done a much better job than the T1S and the BFG prior to that. Traction hasnt been a problem, then again I am not FI
i dont know rich maybe with all my susp mods and daizen bushings , my setup is outdoing the tires or overtaking the tires cap , maybe
Could be. I only have the coilovers, daizen sways and STB front and rear and thats it.
well since you guys are talking about matching up front tires to rear tires and sidewalls
what sizes should I get... right now my fronts look beefier than the rear
how can I get the rear to match ??
Im currently using Nitto555
245 35 20
275 30 20
I was thinking of going w/ falkens
245 35 20
275 30 20
