Recommended tire pressure for IS350 Sport?
I’m curious what others with the IS350 sport have there tire pressure set at.
I checked my tires today and found that all four were at 45psi (too high).
FWIW, the owners manual say’s 35 for the front and 38 for the back.
I was really surprised how much the ride smoothed out when I set mine at 37 front 40 in the back today. Night & day difference. I’m still experimenting.
I think I’ll try 40 in the front and 43 in the back next and see which set up I like best.
Tire pressure makes a huge difference in ride characteristics of the 350 with 18,s. Check yours out!
![Rock On](https://www.clublexus.com/forums/images/smilies/rockon.gif)
i was running on 50 all around...for some reason when i saw 50psi max on the tire, i figured i needed it at 50. now its about 40 around the car. maybe still too much. but i wonder how much going to 35-38 will change in gas mileage versus the 50 i was at.
Super Moderator
Seeing as someone made the mistake of confusing max pressure with recommended pressure, I thought I'd mention another common newbie mistake. Always check your tire pressure when the tires are cold, e.g., driven less than a mile. If you do it when they are warm, you'll end up with too little air in the tire. The logistics of this were difficult when I was getting my air at the filling station, but now that you can buy tire inflators for $20 at WalMart, it's easy to check them first thing in the morning before the car has even been started.
Which in theory give you better gas milage?
yah, the theory is that the higher the psi, the better the gas mileage, but its prob true that the diff from 35/37 to 45/50 wont even be noticable. but to some, little is better than nothing these days.
