06 Wheel compatibility
Old 05-11-06, 09:25 PM
nardeezy
nardeezy's Avatar
Default 06 Wheel compatibility
I was wondering what other vehicles might fit our wheels. I bought custom iforged wheels for the GS. How would they fit on another vehicle? Or, are there vehicles that have comparable wheels spec's (particularly the offset) with the GS? I was wondering if my wheels would fit on an Infiniti M?
Old 05-11-06, 10:24 PM
rominl
exclusive matchup
rominl's Avatar
i knwo the 3gs and 2gs seems to share about the same wheel setup
Old 05-12-06, 09:37 AM
Eternity3G
Eternity3G's Avatar
The wheels will fit the Infinity M-series cars, but the Hub Bore is larger on the Infinity so a different or additional hub ring is recomended. You can also re-insert the wheels to a 5x112 PCD from the 114 to fit on certain Mercedes Benz applications. The wheels also will work on the LS430.
Old 05-12-06, 09:54 AM
larrs
larrs's Avatar
Can it go the other way? Can you fit a 5x112 to a 3GS? I don't understand how you can fit a wheel when the bolt pattern is different.
Old 05-12-06, 10:15 AM
Eternity3G
Eternity3G's Avatar
Yes it can go the other way. That's how I was able to fit Brabus wheels onto the Lexus 2GS B4. Basically, since the 144-112 PCD is so close to each other, (about 1 credit card thickness from hole to hole), a reputable machine shop is able to play with the hole and insert a ?steel? insert sleeve to adjust the PCD. I believe the charge on this is about 25-30/wheel.
Here's one of Brabus MB III:
Attached Thumbnails 06 Wheel compatibility-brabus-monoblock-iii-3pcs-2_resize.jpg
Old 05-12-06, 10:16 AM
Eternity3G
Eternity3G's Avatar
Default Brabus MB IV
Another One
Old 05-12-06, 10:17 AM
Eternity3G
Eternity3G's Avatar
Default Brabus MB V
Another one
Attached Thumbnails 06 Wheel compatibility-brabus-monoblock-v-2pcs-2_resize.jpg
Old 05-12-06, 01:42 PM
nardeezy
nardeezy's Avatar
Basically, the bolt pattern and offsets are compatible with the Infiniti M but I may need a different hubcentric ring?
I'm not sure if we will keep this car forever. If I were to sell or trade it in I wanted to know what other cars I can successfully use my custom wheels on. I like the Infinit M45.
Old 05-12-06, 04:08 PM
Eternity3G
Eternity3G's Avatar
Yes, depending on what the bore of the wheel is (most are 73mm), you will need to get a hubcentric ring. DO NOT get a "close enough" one Even the slightest difference may cause vibrations.
Lexus = 60.1mm
Infinity M45 = 66.1mm (same as 350Z)
So, you would need to get a (if wheel is 73mm) 66.1mm-73mm ring. Because the 350Z is so popular, it should be no problem finding these rings. They usually sell for around $15-25/pc.
Help this all makes sense... I tend to ramble sometimes....
Old 05-12-06, 04:09 PM
Eternity3G
Eternity3G's Avatar
Default Infinity Hub Ring
Here's the M35/45 ring
Old 05-12-06, 04:10 PM
Eternity3G
Eternity3G's Avatar
Default 73mm outer
Most wheel hubs are 73mm...
Old 05-12-06, 04:27 PM
nardeezy
nardeezy's Avatar
Sweet, thanks for the info. I can request for a hubcentric ring from iforged if I were to trade. The main thing is as long as the offsets, bolt pattern and clearance for brakes are good. I need that double verified. Eternity3G, do you know someone who has swapped wheels from an 06 GS to an 06 Infiniti M? If tire size is an issue I can always change those out. I'd hate to sell the gorgeous wheels if we traded or sold the car. Also, I'd lose major dough by selling them used.
Old 05-12-06, 05:40 PM
Eternity3G
Eternity3G's Avatar
Sorry man, never tried the switch over before, but when I do wheels and tires for M's, I just order the Lex fitment usually, and use the rings. Tire sizes are frt. 245/35-20 rear 275/30-20 for the M45. So... pretty much the same... Sorry I couldn't be more help!
Old 05-12-06, 06:40 PM
Eternity3G
Eternity3G's Avatar
I remember that iForged wheels are not hub-centric (i'll check with Vince on Monday) and the bore should be 73mm. BUT, if he did make the wheels hub-centric to the Lexus, than you can always send the wheels to a machine shop to open the center bore to 66.1mm - perfect to the M45. It's an easy process that costs around 25-35/wheel.
Old 05-12-06, 06:59 PM
nardeezy
nardeezy's Avatar
Good thing we have an in-house machine shop. If it's just the center of the wheel i can slap it on the CNC Fadal and bore it out with an end mill.
Quick Reply: 06 Wheel compatibility
