Install TPMS on New wheels.. (PICS)
1) Mark the spot where you'd like to open the hole to install the sensor. You want to find a spot with similar curvitures as the stock wheel for best fitment. We are essentially installing a secondary valvestem. (remember you need the entire stem adn sensor unit from factory wheel)
![](http://i45.photobucket.com/albums/f98/EternityE39/Club%20Lex%20Tips/CLDrillingTPMSSensorHole1_resize.jpg)
2) Start with a small bit and drill a pilot hole.
![](http://i45.photobucket.com/albums/f98/EternityE39/Club%20Lex%20Tips/CLDrillingTPMSSensorHole2_resize.jpg)
3) Use a larger bits to open the hole just enough for the sensor to go through. Or to make life easier, use a uni-bit. I forget the hole/bit size... sorry guys...
![](http://i45.photobucket.com/albums/f98/EternityE39/Club%20Lex%20Tips/CLDrillingTPMSSensorHole3_resize.jpg)
4) Attach sensor and stem...
![](http://i45.photobucket.com/albums/f98/EternityE39/Club%20Lex%20Tips/CLDrillingTPMSSensorHole4_resize.jpg)
5) Try to position the new stem opposite the "actual" stem for better balance. You won't have to utilise as many weight when balancing the wheel.
![](http://i45.photobucket.com/albums/f98/EternityE39/Club%20Lex%20Tips/CLDrillingTPMSSensorHole5_resize.jpg)
6) Here's a view of the sensor from the other side after the tires been mounted...
![](http://i45.photobucket.com/albums/f98/EternityE39/Club%20Lex%20Tips/CLDrillingTPMSSensorHole6_resize.jpg)
Originally Posted by teejnut
That's a pretty good idea! Scary drilling into new rims though... where'd you get it done at?
I agree, I'll be scared to have someone drill into my wheels to attached the TPMS system, there must be another way.
GQis350
08-26-12 08:35 PM
