tire recommendation
Tirerack or anyone else,
19x9 with 235/35 and 19x10 with 255/35. I have found conflicting results whether this tire is within spec of the width. I'm not going for super stretched look just somewhere in between. Plus this size has a nice selection of tires, price wise.
Thanks,
John
Thanks,
John
appologize for the formating
Tire 2 - 255/35R19 >Search Tires Tire 3 - 265/35R19 >Search Tires Tire 4 - 265/35R18 >Search Tires
Section Width: 8.85 in 225 mm
Section Width: 9.25 in 235 mm
Section Width: 10.03 in 255 mm
Section Width: 10.43 in 265 mm
Rim Diameter: 16 in 406.4 mm
Rim Diameter: 19 in 482.6 mm
Rim Width Range: 6 - 8 in
Rim Width Range: 8 - 9.5 in
Rim Width Range: 9.5 - 10 in
Rim Width Range: 9 - 10.5 in
Overall Diameter: 25.74 in 653.79 mm
Overall Diameter: 25.47 in 646.93 mm
Overall Diameter: 26.02 in 660.90 mm
Overall Diameter: 26.30 in 668.02 mm
Overall Diameter: 25.30 in 642.62 mm
Sidewall Height: 4.87 in 123.69 mm
Sidewall Height: 3.23 in 82.042 mm
Sidewall Height: 3.51 in 89.154 mm
Sidewall Height: 3.65 in 92.71 mm
Radius: 12.87 in 326.89 mm
Radius: 12.73 in 323.34 mm
Radius: 13.01 in 330.45 mm
Radius: 13.15 in 334.01 mm
Radius: 12.65 in 321.31 mm
Circumference: 80.86 in 2053.8 mm
Circumference: 80.01 in 2032.2 mm
Circumference: 81.74 in 2076.1 mm
Circumference: 82.62 in 2098.5 mm
Circumference: 79.48 in 2018.7 mm
Revs per Mile: 808.0
Revs per Mile: 816.6
Revs per Mile: 799.3
Revs per Mile: 790.8
Revs per Mile: 822.1
Actual Speed: 60 mph 100 km/h
Speedometer1: 60.6 mph 101. km/h
Speedometer1: 59.3 mph 98.9 km/h
Speedometer1: 58.7 mph 97.8 km/h
Speedometer1: 61.0 mph 101. km/h
Speedometer Difference: - Speedometer Difference: 1.064% too fast Speedometer Difference: 1.088% too slow Speedometer Difference: 2.175% too slow Speedometer Difference: 1.745% too fast
Diameter Difference: - Diameter Difference: 1.05% Diameter Difference: 1.08% Diameter Difference: 2.13% Diameter Difference: 1.71%
mdgrwl
01-10-10 10:36 AM
05ES330
Wheels, Tires & Brakes Forum
03-15-06 06:43 AM
Scott1258
01-03-06 09:42 AM
