19x9.5 with 35 offset issues in the rear??
Old 07-07-06 | 06:41 PM
pnwdawg's Avatar
pnwdawg
Default 19x9.5 with 35 offset issues in the rear??
I found some wheels i wanted to buy for my Gs400 ( lowered) 19x8.5 and 19x9.5 35offset all around Axis Milano ..would i have any issues with the back wheels rubbing or sticking out to far and touching the fender.... ..planning on running 275 -35- in the rears or should i go with 30 series ??
Old 07-07-06 | 06:49 PM
BLK98GS3's Avatar
BLK98GS3
i have 19x9.5 in the rear with 275/30 and is lowered on tien cs and i have no rubbing issues....even with 5 people in the car.
Old 07-07-06 | 08:41 PM
PHML's Avatar
PHML
Master Thread Closer!!
Depends on your drop. If no drop....then no problem at all. If drop 1 inch (Ltuned) or lower....with that offset....and fat tire setup....it will be very close.
The tire you select also maybe an issue. I got Dunlop Direzza....275/30/19....and it has tapered edge on the outer corners...so that helps avoid fender rubbing issues. My other set is Michelin Pilots A/S...and those have square outer edge. The other alternative is to run "stretched" tires....ie: 225/35/19 on the 8.5....and 245/30/19 on the 9.5.
Pete
Old 07-07-06 | 08:50 PM
pnwdawg's Avatar
pnwdawg
BLK98GS3 did you have 35mm offset on the rears too ?? So i should be okay getting 19x9.5 w 35mm offset and running -275 30 19 or even go 265 30 if possible??
Old 07-07-06 | 09:06 PM
AZDesertGS's Avatar
AZDesertGS
My rear are 9.5" with 35 offset with 1.25-1.5" drop and mine rubbed just a bit on the passenger side. I had to trim about a 1/4" off of the tab and now it's all good.
Old 07-07-06 | 11:03 PM
rominl's Avatar
rominl
exclusive matchup
CL Folding 10,000
i agree, if you drop quite a bit, it might rub a little bit in the back, but you can just shave the fender
or you can use 265/30, that will help
Old 07-07-06 | 11:42 PM
mole's Avatar
mole
I asked a similar question about a week ago....
https://www.clublexus.com/forums/sho...d.php?t=225308
Maybe this will help too....
Old 07-07-06 | 11:46 PM
mole's Avatar
mole
I just went to the wheelmax site.... take a look, when the wheel comes up you can put in the car info and then it tells you the wheels wont fit....
Now that I have said, I will also tell you I dont know my wheels from my %$# so you may want to go with what the group says since they seem to be some of the more knowledgable I have run into...
the link, http://www.wheelmax.com/wheelcolors....=Hyper%20Light
Good luck, let us know what happens!
Old 07-08-06 | 05:26 AM
TLW's Avatar
TLW
I ran 19x10 +35 with no rubbing whatsoever on 275/30
Old 07-08-06 | 12:38 PM
pnwdawg's Avatar
pnwdawg
Thanks for everyone input i decided on buying the wheels ( off ebay)
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWN%3AIT
$958 shipped to me it's worth the try ...i haven't decided on running 265 or 275 in the rear yet but hopefully i will have some pictures up soon ....
Old 07-08-06 | 02:18 PM
mole's Avatar
mole
Does anyone know about need 4 speed, just wondering cuz their prices seem decent?
http://stores.ebay.com/Need4Speed-Motorsports
Old 07-08-06 | 02:29 PM
sleeper408's Avatar
sleeper408
I was wondering the same thing. They have many many wheels on their site.
Old 07-11-06 | 11:52 PM
Lexus GS3's Avatar
Lexus GS3
Trouble Maker
I'm running 19x10 +37 offset on the rear with 275/30/19 tires lowered over 1 inch with Tein CS no RUBBBING AT ALL.
Old 07-13-06 | 05:34 PM
AZDesertGS's Avatar
AZDesertGS
BEWARE of buying from them. I bought there "Speedy Octane" wheels last year and they DO NOT FIT. He mentioned after I bought them that I MAY need to put a 2mm spacer on the fronts so they fit. Well gues what......all 4 wheels didnt fit and I had to put a 5mm spacer on the fronts and 2 mm spacer on the rears cause all 4 wheels were hitting the calipers.
Go to Derrick at D2 and be done with it......don't f#$% with these guys IMO......
Old 07-24-06 | 05:35 PM
PlatGS400's Avatar
PlatGS400
Damn I LOVE the search feature!!! I wanted to ask the exact same question.....and there it is....answered and everything.
