steering wheel shake...
i have an 01 gs300 with about 50k miles , i ve noticed that when iam on the highyway at about 60 mph , my steering wheels starts to shake real bad , it keeps going until i pass the 80mph mark . i was wondering if anyone has the same prob. ? i dont have rims just the stocks and no lowering springs either...
My steering has alot of play and feels unstable at high speeds.. I went to get a province inspection to renew my plates and the car didn't pass. Mechanic told me the lower control arm bushings are shot. I have over 100K Miles though.
Some things to consider:
Wheel balance with the Hunter 9700 machine for precise wheel balancing.
Daizen bushings or replace lower/upper control arms.
Adjust steering pre-tensioner (worked for some I believe)
Ball joints if you havn't done them.
Check tire pressure like mentioned already.
I'll let you know how it goes with my Daizen bushings install.
I had the same problem with my car when I first bought it. It would shake right at 60mph, but if I accelerate to 70mph or so, it goes away.
I had to get my front wheels balanced. That solved the problem. Do that before you spend a lot of money on bushings.
__________________
1999 Lexus GS400
-Stock
MUAHAH
__________________
1999 Lexus GS400
-Stock
MUAHAH
mine car is doin the same i replaced all 4 tires all balanced nad did an alignment still has the stumble its slight but its still there i thougt it was just balance but eHhhHs when im at 100 it doesnt feel like that when im below 50 it doesnt feel like that, it is around the 55-65 mark i feel the stumblin ??
BoostAddct
Suspension and Brakes
17
10-28-11 09:29 PM
black_gs99
13
02-10-07 11:54 AM
