wheel fitting
Originally Posted by LEXBUBL96
Will The Lowenhart LD1 20' wheels fit on an Infinti G35 sedan? They came off a 2000 GS300. I dont know the measurements.
I am pretty sure you can get an answer.
Originally Posted by SSK0771
I am pretty sure they will fit. GS and G35 Sedan use similar offset but I think GS can take little more aggressive. Check on G35driver.com
It should be the same fit... Just make sure you have the correct center rings... YOu can buy them usually for $40-$60 per set of 4... the wheels should be bored to one of 3 bores: 73mm/66.5mm/66.1mm. You will need a ring that runs from one of those 3 sizes to a 60.1mm. I just did a G35 sedan with a set of GS wheels...
frt 20x8.5 et45
rear 20x10.0 et47
I know you have a 2gen 300, but just be careful if you decide to transfer to a 06+ GS430 as you might run into brake caliper clearance issues...
frt 20x8.5 et45
rear 20x10.0 et47
PNWMachine
06-14-19 01:24 PM
