IS350 19" staggered tire sizes
I have been reading about everyone's wheel and tire purchases, and I have decided to go with 19". However, I see the most popular tire sizes are these:
Front 235/35-19 - 25.48" tall, 2% speedo error, 76mph instead of 75
Rear 275/30-19 - 25.50" tall, -2% speedo error, 73mph instead of 75
The stock tires are these:
Front: 225/40/18, 18x8, 25.09" tall
Rear: 255/40/18, 18x8.5, 26.03" tall
The stock tires are 1 inch taller on the rear as designed. Why is everyone putting on tires that are about half an inch too short on the rear? Is there a fitment issue? Why wouldn't the best setup be the following?
Rear 275/35-19 - 26.58" tall, 2% speedo error, 77mph instead of 75
If these would fit, it would also fill the wheel well much better. Am I missing something?
Thanks.
Thanks.
Ok here what I came up with For the Back. Here the link if you want to figure out the rest.
http://www.1010tires.com
---Stock OEM Diameter:---
======---Stock OEM REAR Diameter:---==================
REAR TIRE info: Rear: 255/40/18, 18x8.5, 26.03" tall
STOCK Back Tire Diameter= 26.03" tall
Sidewall Height: 4.01 in 101.85 mm
============AfterMarket Setup REAR ===============
[Rear] AfterMarket Setup --> 265/35/19''
Diameter = 26.30" tall
Diameter Difference: 1.03%
Speedometer Difference: 1.036% too slow
Sidewall Height: 3.65 in 92.71 mm
======---Stock OEM Front Diameter:---==================
Front Tire Info: Front: 225/40/18, 18x8, 25.09" tall
StockFront Tire Diameter= 25.09" tall
Overall Diameter: 25.08 in
Sidewall Height: 3.54 in 89.916 mm
============AfterMarket Setup FRONT===============
[Front] AfterMarket Setup --> 225/35/19''
Diameter: 25.20 in 640.08 mm
Diameter Difference: 0.48%
Speedometer Difference: 0.484% too slow
Sidewall Height: 3.10 in 78.74 mm
============AfterMarket Setup FRONT ===============
Dam Tired after this one.
Why was this thread moved? It is very specific to the IS350 only. I never check the wheel forum, only the 2nd gen IS area because I'm interested in EXACT tire fitment for that car only.
Anyway, so the closest for the rear may actually be 265/35-19. I don't see anyone doing that on the rear of the new IS. Anyone? Is there a reason? Why is everone putting on tires that are way too short on the rear?
There are several matching sets in the sizes I was thinking of going with:
235/35-19 Front
275/35-19 Rear
My original question is why do most people on the new IS go with a smaller diameter in the rear than stock? Does anyone have good or bad news about trying these two sizes front and rear?
235/35-19 Front
275/35-19 Rear
