Front +20mm Rear +42mm fit '99 GS?
Originally Posted by BklynJay
19x8.5 +20mm and 19.x9.5 +42mm off a 350z I believe fit a lowered '99 GS without any modifications?
Originally Posted by Neo
Not very good specs for the GS. TOO aggressive in front and not enough in the rear.
NOT VERY GOOD Specs for 350Z also. Its the other way around on Z. Front wheel will OK but rears are too conservative for Z. I know because I use to have a Z Roadster up until 2 month ago.
I did the calculations on that, and the rear 19x9.5 +42 sits 9mm further inboard than the front 19x8.5 +20.
This will look very strange- the front will be almost outside the fenders and the rears will be tucked in about 19mm (3/4") from the fender. Just to make it look right you'll need spacers on the rear.
If these really came off of a 350Z, it must have looked awful. You'd need a 25mm spacer to get that 19x9.5 +42 anywhere close to the fender.
Weird set-up. If these offsets are correct, I'd keep shopping.
Hollywood
Wheels, Tires & Brakes Forum
56
06-15-06 04:03 PM
