18" Vs 19" Wheels
From what i have heard in the past the bigger the wheels the slower the performance. I am running 19" with stragger setup , i notice on the launch at a light is a little slower than my 17" stock wheels ( but i could be wrong) . Between 18" , 19" , 20" i personnly like the 19" for looks and performance but not all show
This is a topic of a lot of discussion in the past here on CL, here are a few threads to get you started I found using search
Threads on 18's or 19's
https://www.clublexus.com/forums/sho...hlight=18s+19s
https://www.clublexus.com/forums/sho...hlight=19s+20s
Nice wheel guide
Polls in the voting booth
https://www.clublexus.com/forums/hall-of-fame-and-voting-booth/98821-did-you-would-you-upgrade-your-wheel-size-from-oem.html
https://www.clublexus.com/forums/sho...d.php?t=128050
Nice wheel guide
Dave, thank you for the threads, they helped on some insight but i'm still considering if i go for 19" and lowered, maybe it could not handle corners as good as 18" (that's what i've read from the comments from CL members) and19" does look visually perfect on a 161 GS
A larger diameter wheel has the "potential" to create a larger moment (torque in lb/in) working against acceleration. Weight distribution plays a big role here...if most of the weight in a wheel is distributed further away from it's center it will have a larger moment than a same sized wheel with most it's weight near the hub (center).
With all that being said...reducing unspung weight is a great way to reduce time for wheel spinup. It will also make the ride a little more sporty; easier cornering since the gyroscopic effect is reduced and road force will be sensed quicker by the shock absorber...better feedback.
A heavier wheel will ride smoother but need more force for turning.
looks and style aside, for example, if you get the volk racing te37, those are some seriously light weight wheels even at 19s.
Originally Posted by GSLexi
so how would 18" G35C wheels perform compatred to stock wheels on a 98 GS3, or any other 19"?
I would really like to put on 18" G35C wheels but are they meant for performance?
Like rominl stated; you can get more sport out of a lightweight forged 19" wheel; when compared to a heavier 17" or 18" wheel.
Rominl,
Very interesting point you've made. I do have the heavy chrome 18's and even though my car is lowered 1" all around, I do feel some minor uneven float around the corners. 19's made in lighter material seems to be the right direction that I may go in the future. But then again, would the 20's handle even better w/ the lighter 19's. Or it isn't much of a big difference other than the 20's filling up the wheel gap space much more for the looks.
thanks..teeman3
thanks..teeman3
i don't think 20s will help handling much, coz' if you compare same brand and model wheels, between 19s and 20s, 19s have to be lighter. and 19s already have low enough profile tires imho for handling imho
Not all cast wheels are heavy, Enkei RPF 1 are processed in cast technology but they are light and strong, 19'' wheel alone is about 20 pounds comparing to many other cast wheels which are 30+ pounds each wheel, so right there is 10 pounds weight savings on one wheel only.
40lbs total is a huge difference in performance accel.&cornering
Weight is very important, in this case MORE IS LESS
For performance usually the smaller the wheel the better it is for performance. So its hard to compare 18's and bigger. I can only give my own experience with both 18's and 19's on a Supra. But the bigger the wheel the less you have off the line. When i ran the 18's they felt more like stock verses the 19's which took just a little more to get her going. as for cornering i heard that the wider the wheel the better.
rdgdawg
03-27-08 10:31 PM
