can i safely run a 8mm spacer on the rear of a 2nd gen gs??
I am looking at adding some spacers to the rear of the gs.I have a set of non hub centric 8mm spacers.I know most say that 5 mm is the max but is the extra 3mm gonna make a huge difference??I just dont want the wheels to fly off while driving...Any info is appreciated! Thanks
BTW, if you decide to do it you'll have to replace OEM studs with longer and stronger aftermarket studs
8mm spacer=10mm longer stud (over OEM )
Whatever spacer you want to use, the rule is at least 7 full turns on lug nut in order to secure the wheel(s)
Hope it helps a bit
- Jake
I have another idea
You can use 15mm H&R hucentric spacer which attaches safely to wheel hub and have it shaved down to 10mm on CNC machine. This way you'll be able to run spacer close to your specs and it will be hubcentric at the same time. I belive it will be the best option for you, very safe at least
