help with longer wheel stud, with spacer
i put 10mm spacer in the front so i need to change the oem stud, but i dont know wht length i sure get for it. so any help!
where to buy longer wheel stud??????
need longer wheel stud for aftermarket rim, using 10mm spacer, can some1 give me wedsite or number to call to order longer wheel stud.
2IS OG
Wheel studs are DEFINITELY an area where you don't want to take any chances - get yourself some quality ARP studs (part #100-715). These are 2.85 inches instead of the 2-inch stockers (it may fit other cars, but I checked and know for SURE that it fits ALL IS's - 1st or 2nd Gen). See pictures below - the bolt at the top of the second picture is the stock wheel stud, Toyota/Lexus part #90942-02070.
Javier
Javier
so busy dont have any time to take pic, when i do i will post, also the stock stud where it came off ur 2IS or 1IS? ,i just check those stud is around $35 in 5pcs, so that is like 70 plus the shipping fee hahahaha
chubby
CL of Southern California
07-19-07 01:30 AM
