Wheel and Tires Combo...
I have a 2006 Lexus IS350 and I am thinking about purchasing Giovanna Sabina Wheels.. The size I want to run without rubbing and hopefully lowering the car with Eibach Pro Kit is 19x8.5 FRONT +38 and 19x9.5 REAR +40.. My question is what tire size should I go with??? I want to fill out the rims with the correct tire size, but I also don't want any rubbing... I was thinking 235/35/19 or 245/35/19 FRONT and 265/30/19 or 275/30/19 REAR... What do you think will be the better fit??? Keep in mind filling out the rims...
Thanks,
Dan
Thanks,
Dan
Being that your 2nd gen IS comes factory with a taller tire in the back, (225/40/18-front and 245/40/18-rear) I would recommend running a 245/35/19 -front and a 275/35/19 -rear. Now keep in mind that this tire size is about 3/4 of an in taller, but it keeps the same ratio (height-wise) front to rear.
Hope this helps,
Yuji
Hope this helps,
Yuji
sincityIS
08-24-07 09:06 AM
