245s on stock 17s?
i dont consider it an upgrade. from what i've read the GS is not safe to drive in snow/ice with regular all season tires. im just shopping for winter tires and found a [used] set of winter tires for a good price. the only thing is the extra 10mm on tire width. beggars cant be choosers...
Everything in Moderation
I ran 245/45/17 on the stock 17's for years. They're no problem. The only thing is that the tire is not only 10mm wider, it's a bit larger in circumference too. Very slight speedo difference, not to worry.
Yes winter tires are the way to go. It makes a huge difference to whether you can move at all, vs. being able to drive around reasonably. I swap mine off every November thru March.
