Just want to make sure
Old 10-03-06, 08:08 PM
p_r_i_m_o
p_r_i_m_o's Avatar
Default Just want to make sure
Hey guys just wanna make sure im going to be ok ......I have an 01 GS300 and im buying wheels ASAP ....The specs im looking at are 20x8.5 offset 40 with 245/35/20 and rear im doing 20x10 offset 40 and running 275/35/20 ...my suspension is stock currently but i will be purchasing coilovers Tein CS to be exact in the next week or so ....Will have any rubbing with these offsets ? i did a search but with so many different people running different setups i just decided to ask .....thanks in advance for any help
Old 10-03-06, 08:30 PM
ARISTOh
ARISTOh's Avatar
if your getting coilovers you can adjust the height 20's i have on my car no rubbing at all it all depends on the wheel and tire its kinda like a cracker jack box... gotta open it to see whats inside once you oput the coilovers on if it rubs when you drop it either raise it or get you fenders rooled or even cut depending on how agressive you want to be... oh btw... pictures are a must in this club.
Old 10-03-06, 08:32 PM
corkycal
corkycal's Avatar
the fronts should clear but the back may require some minor mods. depends on your tires. if you're going to dump it low, the camber may be good so you don't have to do any mods to the rear fender.
Old 10-03-06, 08:37 PM
p_r_i_m_o
p_r_i_m_o's Avatar
thanks for the help guys .....My tires are going to be Nitto NT 555
Old 10-03-06, 09:00 PM
ARISTOh
ARISTOh's Avatar
Nitto NT555 for 20's... you dont have to listen to me but cause ive only ran through about 3 sets cause i got them really cheap but those tires are &^$ (*&%(#(&^%)( &^%$$*()^$%$# $^*%$# to use a small line of words i dont know about any other size... but from my experience NITTO SUCKS!
Old 10-04-06, 01:07 AM
lexusondubs
dubsonlexus
lexusondubs's Avatar
please dont get nittos !! i had nittos on my old LS 400 and 3 out of the 4 tires split the inside and outside of the sidewall very dangerious nitto gave me a full refund !! i ran for the hills and got some toyo's !!
Old 10-05-06, 01:19 PM
BUSTN
BUSTN's Avatar
get better offsets and tires.....
thomastan
03-24-09 05:46 PM
iron_lungs
03-06-09 12:08 AM
questnyc
05-21-08 11:34 PM
dizzle
10-01-03 11:45 AM
GammaLex
06-09-03 02:17 PM
Quick Reply: Just want to make sure
