245/45ZR17 General Exclaim UHP tire
I'm about to replace noisy stock 225/50VR17 Dunlop 2050 tires on my 2006 GS300 with 245/45ZR17 General Exclaim UHP tires. This tires have best rating in Tirerack's survey.
Is it a god idea?
Is it a god idea?
You got dunlops on your GS? Aren't the factory tires yokohama advans?
I may be a tire snob, but I wouldn't buy dunlops, or generals, or any other tires of that variety. for summer tires, if you don't mind 20,000 mile tires, i'd go with bridgestone re050-a. currently $82 a tire on tirerack closeout, you won't find better tires at twice that price.
also, look out with the size change you're making, those tires are almost an inch wider than the tires you're replacing, your tires will look a little more "squared off" around the shoulder, you'll get a bit more sidewall flex (the cornering response will be a little slower, but the ride will be smoother), and they may not even fit your wheels.
Where did you see $82 per tire? Tirerack shows me $152 for Bridgestone Potenza RE050A Pole Position 245/45-17.
Edit: Well I did find it - it's not a pole position tire.
Also, why do you think they won't fit? There is no RE050A in size 225/50-17 anyway.
P.S. Just checked the manual: stock rims are 7.5 wide and 245/45-17 tire requires 7.5-9 rim width so I guess it should fit. I kind of hesitant to buy discontinued tires. What if I'll need an emergency replacement?
there are much better options...
keep in mind when people rate stuff online, they go based on value to themselves as well, in which the general is a great value, however, it is sub-par to any michelin, bridgestone, or other high end tire...
the 245's will work, but the Generals are marginal at best...
between the wide oval and the exclaim?
first off, I don't even consider them in the same category, but secondly, they are about the same in terms of quietness... the wide oval just performs a WHOLE LOT better, handling wise... wet weather wise, the general is pretty darn good...
prior to the BFGoodrich KDW's I have now, I had Exclaims... thought they were great, until I lowered the car... then quickly realized I needed something with more cornering grip, as the Exclaims shortfalls in the handling department were quickly found...
Wald GS
Wheels, Tires & Brakes Forum
07-28-03 07:57 AM
