Will 20x9 wheels with 275/35/20 tires cause rubbing on front fenders?
Keep in mind that I'm lowered on NF210 springs. If I'm going with 20's, I'm not going staggered b/c it's AWD. Yes, I know many people will say that it's perfectly fine running a staggered setup with an AWD tranny, but I'm not interested in going that route. I know that offset plays a huge role, so is this combination possible with the correct offset? I do not want to roll, cut, or do any modifications to the fender.
I know SanseiGS43 is running 20x9.5 up front, but I'm not sure what the tire specs are. Definitely won't be my winter set up unless I'm in the mood to go drifting.
Why would anyone want 275s on the front!? While the steering may be power assisted that much bigger footprint is going to put a lot more strain on the system. Plus noise will be higher, weight is higher. Makes no sense.
I want to go as wide in the front as possible b/c I'd be running the same size all around since I'm not staggering. If 275 isn't possible, what do you think the widest size would be?
You don't wanna stagger because of AWD I take it, or because you want to rotate the wheels? If only cuz of AWD you can get staggered tire sizes that are very close in circumference which shouldn't be any problem with the AWD.
Another approach is spacers on the back to push them out a bit.![Thumb Up](https://www.clublexus.com/forums/images/smilies/thumbsup.gif)
255 should be doable, but don't take my word for that.
I know it's in a different class, but the Audi S8 comes stock with 265/35/20 all around so that's why I was wondering if we could do that on the 3GS.
