will 255/40s fit supra rims up front on sc300
Old 11-10-06, 10:14 PM
1sxyrxy
1sxyrxy's Avatar
Default will 255/40s fit supra rims up front on sc300
just like the title says.. i popped one of my tires and have a chance to get some cheap 255's and was wondering if they would fit. but im not thinking so. i have stock height on supra rims on my sc300
Old 11-11-06, 04:27 AM
Chawk60
Chawk60's Avatar
If they are on 17s they should fit.
Old 11-11-06, 10:01 AM
1sxyrxy
1sxyrxy's Avatar
they are 17' i just didnt know if i would rub or anything seems like they might hang over the rim a little
Old 11-11-06, 03:56 PM
ki_soarer
ki_soarer's Avatar
im rinning 245s and lowered, so i dont think you will have a problem...
however, your car will track like a sonofa*****! mine follows grooves in the road now, i couldnt immagine with a wider front tire and on stock suspension. thats actually the size recommended for the rears.
Old 11-11-06, 04:58 PM
Sc dRifta
*****Do not buy from this member until further notice *****
Sc dRifta's Avatar
265 front lol ive tried it it'll break your steering rack if you drift like me. thats from expierience!!!!
Old 11-14-06, 05:52 PM
CantSeeMe
CantSeeMe's Avatar
I dont see how 255s would be a real problem to fit up front on 8''TT wheels. Theres definately more aggressive wheel/tire setups out there.
BTW, There's at least 1 CL member who is/was running the 9.5'' rear TT wheels on all 4 wheels. with little or no fitment issues. I dont recall who, nor do i remember the tire size he was using , im assuming 255 or 275.
Old 11-14-06, 06:17 PM
np20412
np20412's Avatar
I have 17x8 (not TT rims, but TT rims are also 17x8) up front and I'm running 245/45/17 on them and no rubbing at a +45 offset, so basically 255/40 WILL fit as that is an even thinner sidewall and TT rims are +50 offset.
Just as a reference, one time I had to mount my rear wheels (17x9, +45) on my fronts and those are wrapped with 255/45/17 and there were NO rubbing issues or fitment issues. That's a wider rim with the same size tire, so you should be alright.
Old 11-14-06, 06:24 PM
chitwnsazn
chitwnsazn's Avatar
yes it will rub...at least if you on on espiler type drop. I had the same size up front and then had to get smaller. Anyway the diameter might be alittle larger in the front than the rear, depending on the size of the rears, making it look pretty odd.
Old 11-14-06, 06:26 PM
np20412
np20412's Avatar
he is at stock height, at that height it will be so 4x4 that it wont even matter
Old 11-14-06, 06:27 PM
chitwnsazn
chitwnsazn's Avatar
245/45/17 front and 275/40/17 in the rear should be perfect with diameters almost exactly matching the stock sc300 wheel size so your speedo isn't off.
Old 11-14-06, 06:28 PM
chitwnsazn
chitwnsazn's Avatar
lol haha didn't realize that, but i guess it will work but like i said, the front wheel and tire diameter might look larger than the back...
Old 11-14-06, 06:30 PM
chitwnsazn
chitwnsazn's Avatar
no way hes running 275 on the 9.5's in the front. I don't even think u can turn...
np20412
np20412's Avatar
yes that will work too!
I'm running 245/45 on the 17x8s and 255/45 on the 17x9s
Next time i gotta buy rears, i'm going 265/40/17 for a little wider look out back
Old 11-15-06, 05:53 AM
Chawk60
Chawk60's Avatar
The Final Answer: I am running on stock TT rims: 255/40 F 275/40 R on Tien CSs lowered to F: 1.5in R: .75in over the wheel . No rubbing anywhere.
Old 11-15-06, 07:19 AM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
same widths / heights here, and no problems, even with lower offsets, and the car lowered 1.6" or so...
Quick Reply: will 255/40s fit supra rims up front on sc300
