sc400 Lug Torque Specs
Hi everybody.
Did a quick search but nothing came up. Just looking for a quick answer to a simple question.
What is the proper wheel lug nut torque specs for a 1992 sc400?
Thanks!
Thanks!
Banned - could not follow forum rules
As hard as you can turn with your hands while using the lug wrench (Unless you are super strong dude) Then go maybe %75 of your power......Those are my specs...
http://auth.owners.lexus.com/lexusow...05rx330o/4.pdf
IN CASE OF AN EMERGENCY
570
CAUTION
When lowering the vehicle, make sure all
portions of your body and all other persons
around will not be injured as the vehicle is
lowered to the ground.
Have the wheel nuts tightened with torque
wrench to 103 N·m (10.5 kgf·m, 76 ft·lbf), as
soon as possible after changing wheels.
Otherwise, the nuts may loosen and the
wheels may fall off, which could cause a
serious accident.
570
CAUTION
serious accident.
