Help With Tires PLs
Search Function Inc.
Hi guys! I need some info on these rims. What tires do I need to use to clear and have no rubbing? I have an LS400 1st gen.
19X8.5 (+35H) & 19X9.5(+45)
I don't know much about all the offsets and measurements so please explain it to me like you would to a newb
Well, here is what i know.
The lower the offset, the more out the wheel comes from the wheel well. Also, if you wanna check call tire rack and they'll tell you offsets. Here is a picture showing you what offset means relative to the center of the wheel.
![](http://www.tirerack.com/wheels/images/tech/offset.gif)
Hold up...lower the offset the more it comes out of the wheel well? Shouldn't it be less offset less it comes out? Thats how I figured looking at the diagram.
GSNav is right...+40 sits IN further than +30...
That setup should be fine on your LS...on the front, just be careful...if you put too large of a tire, you MIGHT rub...a 245 up front should be good...
+35H means that the wheels "pad" (where it mounts to the car) is +35mm OUT from center. The "H" means it's a "high" disk...usually needed to clear the brakes...rears can be normal, lower, or sometimes superlow disk to get a deeper lip...
Your rear wheel will sit in a litte...you'll probably have a like a 1/2" spacing (not noticable unless you're REALLY looking for it)...you could have done a +37 offset out back....
