Widest tire for a 10 inch rim?
Old 01-29-07, 12:40 PM
morris
morris's Avatar
Default Widest tire for a 10 inch rim?
So it is time for new tires, I currently have 285x30x19 in the rear on a 10" rim. In the front I have 245X35x19 on 8" rims up front.
I need to know what is the widest tire I can use on these rims.
According to tirerack I can put a 295 on the rear but that is it. I have been told that I could actually use a wider tire in the rear, can anyone confirm this ? If so what is the max width?
Old 01-30-07, 07:28 PM
morris
morris's Avatar
bump this message
Old 01-30-07, 07:59 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
you can use a wider tire, but how wide do you really wanna go??? 305's would work ok, but IMO, when you get too wide of a tire, the tire hangs over the wheel so much it looks silly...
Old 01-30-07, 08:06 PM
morris
morris's Avatar
Well I need as much traction as I can get, the tires break loose to easily. Do you think 305's would fit? The guys that put the 285s on had a tough time squeezing those on.
dchan865
RX - 4th Gen (2016-2022)
13
10-30-18 07:18 AM
np20412
03-05-07 08:09 AM
e-man
11-11-04 04:00 PM
Taka
SC- 1st Gen (1992-2000)
13
11-04-02 09:03 AM
DeniskaGS4
05-25-01 07:14 AM
Quick Reply: Widest tire for a 10 inch rim?
