Wheel Spacer Questions
stock, the front wheels come out further than the rears. i think if you do 25mm front and 30mm rear, the fronts will stick out past the rears. adam5xx2 with the slammed blue GS has spacers on front and rear. i believe both sets are less than 20mm or less and his car looks tough as hell.
GS Fonz im running the stock 17x8s i believe its +45 or something near there
ChrisES heres a link to Adams car. 15mm front and 20mm rear https://www.clublexus.com/forums/sho...d.php?t=228780 i hope that helps you make a decision
I just don't trust those spacers. they seem like a rig job to me. I'm sure most people have no probs with them, but I personally just wouldn't mess with them.
I am putting these on the stock rims. NYC does not really allow me to go to some crazy size, and there are only a few other rims that I like. If I find a good deal on some new GS430 18", I will put those on.
As far as the spacers being a rig job. I always thought the same thing. But I recently met a guy that has been using the H&R ones for about 3 years on hist 800hp mustang. He never had an issue. Plus H&R is a very reputable company. I am willing to try.
to make you feel better, i've driven over many bumps and potholes in NYC. never an issue in the +/- 10k miles ive had them on. matter of fact, i've never read of anyone having any problems running spacers.
what aobut these.. this seems ilke a good deal
http://autosportstyle.com/shop/lexus...s-p-58069.html
theyll fit?
theyll fit?
i tried the 30 mm today, set the wheel out to far. this spacer is fine for the stock gs wheels cause they have a +50 offset. i only need a 15 mm spacer, my wheel is a +40. can you get a bolt on 15 mm or do i need to do the longer studs? the bolt on i dont mind as much, i seen some cars with real hp runnin em. the longer studs im kinda make me a little uneasy.
Vic nyce, I like this spacer. Would you please pass the part number for this one as well. I'd just like to make sure I choose the right ones when I order (25mm).
And will the stock studs be longer than 20mm (spacers)?
Truly, I am concerned about the safety as well, but looks like many have used spacers without issues ...
thanks for the info on the 12mm man i'll try the longer studs tomarrow i kinda planed for this to happen! i will keep it posted up!
