18x10.0 All around on SC400. Need tire rec.
1. The off set will be +24 all around.
2. The car is lowered with Tein Basics.
3. Fenders will be rolled
Will 245-35 front and 245-40 rear work?
Yes, I know it will be stretched, but I do not have an option.
Also, do you think BFG g-Force T-A KDW will work for the stretch? According to tirerack, it has reinforced side walls.
Thank you for your help in advance.
I would assume the KDW's would be pretty resistant to stretching because they are built like tanks. I have no experience, but I have been told by a respected forum member that Dunlop Direzza's are good at stretching and have relatively sloped sidewalls which are conducive to sliding under the fenders.
ps. if you need a fender roller, shoot me a PM. I have one sitting in my basement next to my heat gun. Worked like a charm for me.
Former Sponsor
Well it is not too far outside of the recommended rim width range. However, I have heard of guys whose tires have come unseated in a corner. There is a recommended rim width range for a reason. That said, I doubt the 245/40's would be much of a problem.
