alignment check?
alignment check?
i had an alignment done recently, the only thing out of spec was toe-in (makes sense since i havent done any suspension work, only steering repairs). i went out to tirerack in south bend the same day and replaced my 215/55/16 tires with 205/60/16 tires.
i know everybody is going to say that i should have gotten the tires first, then had the alignment done. but, it was more convenient for me to have the alignment done first thing in the morning and pick up tires in the afternoon. i didnt want to drive xxx miles on new tires, knowing that the toe-in was way off before getting the alignment.
should i be concerned that the difference in sidewall height will have affected the camber significantly?
btanchors
Maintenance
06-25-05 05:27 PM
