Time to replace 17" tires on GS430; looking for recommendations...
#31
2SAVVY-
Surprisingly, in the Dunlop SP5000 line, the 245 and 235/45-17 sizes have the exact same diameter of 25.8 inches, and therefore, 806 revs per mile. The only difference being the 245 has wider sidewall at 9.8" vs. 9.5" and wider thread at 8.8 vs. 8.5".
Yoko AVS dB 235/45-17 (thanks for the feedback, GS400TRD) has a diameter of 25.4" at 819 revs/mile. The 245/45-17 has 25.7" diameter and 808 revs per mile. The SO3 sizes are also very close.
The Dunlop appears to stick like a sore thumb in that its larger size for the 235/45 is more in line with other brands' 245/45-17.
I got the data from www.tirerack.com
#32
Thanks whitels for the info..
Here is a link below to Tirerack's info on the Kumho's I got for my sister.. If anyone has these on their car please by post a review on them for me.. Thanks!
http://www.tirerack.com/tires/kumho/ku_712.jsp
#33
For the Lexus, I really like the Yokohama Db's. They are much quiter, very good ride, and nice performance. Contrary to popular belief, Lexus' are not 911TTs and do not need 911TT tires.
I also sell a full range of tires.
#34
Ok after reading a ton of reviews on various tires that Tirerack carries it really does seem that the Toyo T1-S is the best solution with respect to price and performance..
Dennis maybe you can answer this do you see any problem running a 245/45/17 on the stock GS 17" rims.. Your expertise would be most appreciated..
Thanks!
Ken
Thanks!
Ken
#35
Originally posted by whitels
SCWells72-
You've driven the Dunlop 17 SP5000 for quite a few months now. How is it holding up as far as tire noise is concerned? Is it really that much quieter than the OEM Bridgestones? Thanks.
SCWells72-
I'd recommend them, yeah, especially if tread life is as important to you as sportiness and tire noise.
#36
Thanks!
Ken
Thanks!
Ken
I've run the numbers, though I do not know the factory Lexus offset. (I'm in the aftermarket
#37
Thanks!
Ken
Thanks!
Ken
#38
The 245s will fit with no problem and they will give you a bit more rubber on the pavement and a more "comfortable" ride.
But they will also be more "floaty" and not quite as responsive in handling as the 235s because of the extra height of the sidewall.
Your choice.
Your choice.
#39
I'm gonna say something different and recommend just not getting new 17" tires and just go 18" and get new rims. SOmetimes rims places give serious discount if you get a packaged deal (install + mount + balance + alignment) when you get a set of tires + rims.
I went in one day to change tires for my 16"'s and walked out with 18"' 3 peices for 3K and I would've spent 800 just to replace tires. I then sold my stock rims for 250 each and made 1K there. So for 1200 I got a whel upgrade and lifetime alighnment , balance and happiness
#40
However, to add on to this thread I suggest in ANY size YOKOHAMA AVS SPORT with the V pattern. I've had 2 sets of these and they're great and they LOOK great and I've gotten compliments everywhere I go - Especially from Dunlop SP people hahah
#41
That said, if a customer buys wheels from me, I sell the tires at my cost.
#42
Originally posted by SCWells72
I've been pretty happy with the SP5000s. Honestly, I can't tell a huge difference in tire noise or smoothness relative to the stock Bridgestones, but I CAN tell that cornering is a little softer because of the lower rating of the SP5000s. Not too much, but enough to be noticeable. I'm hoping that the trade-off is that the tires last more than 15K miles. I have about 7000 on them now and the tread looks pretty healthy.
Maybe I'm still dreaming, but hope and hear that the Michelin Pilot Sport A/S maybe that solution.
#43
Originally posted by lexguynj
In my case, I want to be able to detect a significant difference when you change to better tires almost immediately. .
#44
Do any of you have any info/experience on the Firestone Firehawk SZ50 EP? Tirerack gives it high ratings and I'm thinking about getting them to replace my stock 17s.
Also, how "bad" would it be for me to change only three of the four tires? (one of the Potenza RE030s has less than 500 miles on it and the spare is brand new).
Thanks,
--David
Thanks,
--David
#45
Registered User
I have had the Toyo T-1 Proxes on my 98 GS400 for a bit over a year now with absolutely no issues. I think this are GREAT tires and will purchase them agani when the time comes. Further, they seem to be wearing evenly with no issues with accellerated wear on the front inside edge of the tires like I had with the Dunlop SP8000. this may be attributed to the tires or to a proper alignment I had done at Express Tire in San Marcos. I did have the car re-aligned previously at the dealer with the OEM tires and the Dunlops, but had the wear issue like many other owners.
In short, the T-1 Proxes are definitely a big step up from the stock Bridgestones in EVERY way, and a step up from the Dunlop SP8000s. Lastly, I have gotten many comments on the looks of the Toyo's from many random admirers at say, the gas pump. They just look damn good / agressive. One other note, I use the stock 17 inch alloys with 1" rear wheel spacers I got from RMM. Have had the spacers on for 2+ years with no issues. The affect on the look on the rear of the car more than justifies the modest cost of the spacers. IMHO, the car now looks like Lexus should have made it look in the first place. I.E. an aggressive looking car, and not some rice burning aftermarket kludge.
