L-Tuned wheels (OZ Salina) width
According to their website, these wheels are 18x8f and 18x9.5r with 235/40 and 265/35 tires respectively. Does anyone know that these wheels will fit 245/40 and 275/35 tires? The latter numbers seem to be the "preferred" sizes for the 18s. I just wanted to see if I can put tires this size later on (after the pilots are worn).
Thanks for the help.
GX and 2IS Moderator
Should be okay
Neo,
I think you'll be okay - I have 245/45 on my 17"s and the stock size is 235/45. You can probably call the tirerack and they can tell you for sure.
neo,
i think you should check w/steve of carson on the width of the rims... i always thought they are 18x8.5+9.5, if so, 245/275 combo would def fit and looked much much better
Website is correct
According to Steve, the specs are:
18"x8, 235/40ZR18 front
18"x9.5, 265/35ZR18 rear
Michelin Pilot Sport Tires
The L-Tuned wheels come mounted and balanced, lugs and metal valves.
With this in mind, it is still safe for the future tires, right?
