WHEEL SPACERS: whats the biggest u can go and be safe?
Old 05-06-07, 08:02 AM
sc400 2nv
sc400 2nv's Avatar
Default WHEEL SPACERS: whats the biggest u can go and be safe?
well, i just put some 19x9.5 rears and 19x8 wheels on my sc. i want a more flushed look for the rear and wanted to put a 1/4" spacer in the rear... what is the biggest size spacer u can put without changing out the stock studs...and be safe. i know they sell the spacers with built in studs but i would prefer to not cut the stock studs...
i went to a shop and they said that a 1/4" spacer was risky for the rear(i think its about 6-7mm in metric).
anyone with wheel spacers...help!!! your feedback would be helpfull. thanks in advance.
Old 05-06-07, 10:16 AM
EXE.UCF10
VIP|EXEstyle セルシオ
EXE.UCF10's Avatar
The shop is right, it's risky. 3mm would be max, but that wouldn't even be worth it IMHO. You have to either change out the studs to longer ones or go with KICS adapters.
Old 05-08-07, 05:03 PM
pvmike1
pvmike1's Avatar
That might actually be okay. Just make certain that you have at least 6 or 6.5 full turns of the lug nuts to properly secure the wheel.
I run 25mm spacers on my car. They're made by H&R, and have built in studs. I hear a spacer should be at least 15 mm thick in order to be strong enough to accommodate built in studs.
If you cannot get at least 6 full turns with a spacer, or if you cannot use a thick spacer with attached studs, you will need to install extended studs to replace your stock ones.
Also, make certain that the spacers are hubcentric, meaning that the hole in the center of the spacer be an exact fit over the hub. Many places sell generic spacers with a larger hole in the center to accommodate many different hub sizes. However, this may cause some vibration as it is difficult to precisely center them with only the lugs.
If you need a custom sized spacer, I'd call Fred Goeske: http://www.wheeladapter.com/home.asp
He's about 80 years old, and he's got a couple CNC machines to make custom spacers. Pretty reasonable pricing too.
Old 05-08-07, 06:58 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
what offset wheels do you have?
Old 05-09-07, 08:07 AM
Brandon@TR
Former Sponsor
Brandon@TR's Avatar
Your moderator gives PVMikes response his official seal of agreement. 6 turns is very important. We use the term "safety critical".
Old 05-23-07, 05:15 AM
CK6Speed
CK6Speed's Avatar
I absolutely agree with Mike and Brandon at Tire Rack. Minimum of 6 full turns is the rule of thumb I learned as well. Probably I agree so much because I learned it from Ken over at Prime and he probably got the information from Tire Rack
Now, the only thing I have been a bit unclear about was if the 6 full turns was before you torque it down or inclusive?
Old 05-23-07, 06:33 AM
mitsuguy
mitsuguy's Avatar
If you got it properly snug first, it should take only 1/2 turn or maybe 1 turn to torque... a little extra wouldn't hurt...
Old 05-23-07, 06:51 AM
CK6Speed
CK6Speed's Avatar
That is the thing. A few times I've had about 5 1/2 turns to snug (By snug I mean when the lug just touches the lug hole base using fing presssure) before torquing, but obviously after torquing the extra 1/2 turn maybe a little more meets the 6 full turns. Generally I played it safe if I was driving on it and replaced the studs; however, if it was just for a short time like a car show or something I never bothered. If I only get 5 full turns I wouldn't chance it, but that 5 1/2 turns starts to play on the fense and I'm not sure which way I should lean.
Old 05-23-07, 07:00 AM
mitsuguy
mitsuguy's Avatar
~should~ be ok... kinda depends on the thread pitch... if you talk to the manufacturers, the real rule isn't 6 turns, it's that the lug should engage the stud threads by it's diameter... so, if you have a 12mm stud, there should be 12mm worth of engagement...
Old 05-24-07, 02:38 AM
CK6Speed
CK6Speed's Avatar
Thanks for the tip.
Blueshark
ES - 5th Gen (2007-2012)
04-25-15 05:18 PM
JDW379
01-30-14 04:53 PM
DougJoseph
12-10-12 12:04 PM
VNN326
21
12-24-07 10:45 PM
Noypi
RX - 1st Gen (1999-2003)
11-08-07 07:39 PM
Quick Reply: WHEEL SPACERS: whats the biggest u can go and be safe?
