18x11 Fronts 18x13 Rear - TIRE SIZE?
Old 07-17-07 | 04:28 AM
powrserj's Avatar
powrserj
Wink 18x11 Fronts 18x13 Rear - TIRE SIZE?
Alright I am doing something out of the ordinary to my 92 SC300. But having a issue figuring out what tire size to run.
Heres the dilema.
Its gonna be driven not every single day but alot more then usual. I want the tires to have a stretched look but not enough my Lip will bend every which way.
Old 07-17-07 | 09:02 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
wide body kit hopefully?
Old 07-17-07 | 10:29 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Definately wont fit a stock body
Old 07-17-07 | 12:19 PM
SoCalSC4's Avatar
SoCalSC4
That's a tough one... the selection of 18" tire sizes is not increasing,
as 18" is quickly loosing popularity.
I guess you could go with Porsche-ish sizes:
F 265/35-18
R 295/30-18
The rears will be fairly stretched!
A 315/30-18 would be a good choice
if you have the clearance for it.
Old 07-18-07 | 03:34 AM
sleeper408's Avatar
sleeper408
This I gotta see.
Old 07-19-07 | 09:22 AM
powrserj's Avatar
powrserj
Well trying not to really go wide body. If so something a little mild nothing that is gonna change the body lines too drastic. Well the rims are suppose to be coming monday so gonna try 295.30.18 on the rears.
Old 07-19-07 | 09:28 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
What offset on the rims? I don't think that even a super tame offset that a 13" wide rim will fit a stock body. Actually, I would bet they wont fit even with a fender pull.
Old 07-19-07 | 09:42 AM
mitsuguy's Avatar
mitsuguy
I had 295/30-19's on my 19x9.5's with +35 offset wheels... rolled fenders and all and they still rubbed any time the suspension compressed or anyone sat in the back... your 295/30-18's are going to sit about two full inches outside of where mine were, and thats assuming you are running a +35 offset wheel... I'm 99% sure a 13" wide wheel won't clear suspension with a +35 offset, so you are probably looking at closer to a +10 or 0 offset, meaning that your wheels may sit a full 3" or better out from where mine are... mine are considered a "safe flush"
Good luck...
Old 07-19-07 | 01:41 PM
sleeper408's Avatar
sleeper408
If you don't plan on going widebody, I would listen to Mitsuguy. He is a wheel/tire guru.
Old 07-19-07 | 01:49 PM
bb430's Avatar
bb430
You can have the "ghetto" look where the wheels/tires stick out of the fenders with very stiff suspension so they won't touch the fenders at all.
Old 07-19-07 | 01:59 PM
mitsuguy's Avatar
mitsuguy
heh.... that would be attractive on a lexus...
Old 07-19-07 | 02:20 PM
Kohinoor's Avatar
Kohinoor
i have 19x10 19x12 wheels.. they definitely wont fit stock body. youd probably want to go with a 245/40 front and 275/35/18 rear.
Old 07-19-07 | 03:00 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
You callin' my old pick up GHETTO!!!!
Oh wait...........that was from back in 1992. Totally not relevant now!
Old 07-20-07 | 01:01 AM
powrserj's Avatar
powrserj
See how the rear is pulled I want that look just a bit more pull to fit the lines of the car a bit more. Its more of a different look cause I never seen a good pull on a SC with some Camber I think I can make it fit. And it will be on Bags for sure just so it gets the good stance when it goes low and cambers that and NYC is a B*TCH with potholes so need the bags to avoid loosing my kit lol.
Old 07-20-07 | 06:51 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
It's worth a try. I just don't see 13" fitting even with a good pull. I think it'll need a widebody/flares to fit.
Quick Reply: 18x11 Fronts 18x13 Rear - TIRE SIZE?
