EBC Brakes for RX-300
Old 07-27-07, 08:57 AM
REGGIE3
REGGIE3's Avatar
Default EBC Brakes for RX-300
Has anyone put EBC rotors and pads on their car. I have a question about the shims.
I purchased a set of EBC rotors (GD 7229)and pads(DP6628) for the 2001 Lexus RX-300. The stock pads have shims that are placed between the caliper piston and the pads - as well as the opposite pads have shim that is also used behind the pads.
I found I could not use these shims and still fit the new pads over your new rotor. I tried not using the shims but the sound I heard just driving around the block and coming to a slow stop seem to indicate that this setup may be right.
Should I be reusing those shims? I appreciate any inputs anyone might have. I tried to contact EBC through their website but no links would work.
TIA
A
Old 07-27-07, 09:04 AM
Flipsonic
Flipsonic's Avatar
Ask the people at www.perfectbrakes.com.
FYI, I have EBC Redstuff on my ML350 and they still produce lots of dust. It's less than OEM but still too much for me.
Old 07-27-07, 09:25 AM
Lexmex
Super Moderator
Lexmex's Avatar
I have used EBC Greenstuffs many, many years ago on my RX300. Lots of dust...for me more than OEM.
As far as the shims, for several years I used no shims on my pads, can't say I noticed much. When I switched recently to Akebono pads, they came with shims and I started using them.
My uncle and I work on cars and we frequently re-use the shims if the new set of pads does not have them.
Old 07-27-07, 09:30 AM
REGGIE3
REGGIE3's Avatar
Thanks - the problem I had was there was not enough room to use the shims with the new rotors- I was wondering if they were necessary. I think you have answered my question.
Old 07-27-07, 09:32 AM
REGGIE3
REGGIE3's Avatar
Thanks - sent them a email -
FYI
I use Mintex Red Box pads on my A4 and have very little dust. They are strictly a street pad. The RX is my wifes.
Old 07-27-07, 09:35 AM
Lexmex
Super Moderator
Lexmex's Avatar
Come to think of it, I never used shims when I had my EBCs either.
Old 07-30-07, 10:49 AM
Rare1
Rare1's Avatar
This is a big issue I have with EBC GreenStuff pads. They are really bad. I tried them once and took them off after a while. I couldn't stand the brake dust they produce. I contacted EBC and they weren't much help. They recommended some things that didn't work, most of which are obvious and common sense when doing brakes.
Old 08-17-07, 09:24 AM
REGGIE3
REGGIE3's Avatar
I put the pads and rotors on - they look great and work great. No problem with dust.
FinnLS
10-04-23 07:58 AM
Mystery
RX - 1st Gen (1999-2003)
12
07-04-18 02:12 PM
kuuqi
Suspension and Brakes
06-11-12 08:22 PM
oblivionis
14
09-21-10 09:16 AM
cpr greg
12-02-09 09:48 AM
Quick Reply: EBC Brakes for RX-300
