Curious to know - a wheel spacer question
Old 09-02-07, 06:32 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Default Curious to know - a wheel spacer question
Hello good folk,
Now I'm not going to ask what spacers do/what they are/what hubcentric is BUT I do have a question.
I'm pretty set on getting spacers as my offsets are too conservative (ordered the wrong offsets on the rears, real pissed off with that but can't do anything now).
I want to put on 15mm or 20mm spacers to beef them out a bit (so that the tyres are slightly tucked from the guards)... I don't really want the whole stretched tyre look, I just want something to beef the tyres out by a tad bit.
Before anyone say, please don't say to buy new wheels (as it took freaking long enough for these to arrive and I've spent all my hard earned already on these puppies lol).
The spacers will be going onto my Soarer.
There are two types of hubcentric spacers that I've seen:
- All bolt-on spacers (ie. spacer bolts on to OEM studs and wheel bolts onto spacer), like Kics, Night Pager etc.
- Spacers with extended studs (ie. replacing the OEM wheel studs for longer ones), like H&R, Eibach (iirc) and Ichiba USA.
I'm under the impression that the latter type is safer since the original threads have to be removed and replaced with the extended ones, which would essentially fasten the wheel straight to the hub instead of relying just on the spacer to hold the weight of the wheel (but of course I could be wrong).
What are your opinions? Which type of spacer would you guys recommend and why?
TIA
Jose
Old 09-03-07, 04:18 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Anyone?
Old 09-03-07, 05:13 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
10mm or less = extended wheel studs
15mm or more = bolt on adapters...
Old 09-04-07, 06:45 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
Cheers Mitsuguy, just curious to know why?
Old 09-04-07, 06:53 AM
mitsuguy
mitsuguy's Avatar
Any more than 10mm extension and the studs aren't strong enough - they would need to be larger diameter (14mm maybe), especially if the setup was not hubcentric...
Old 09-04-07, 07:06 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Thanks for that mate. I was always curious to know why.
Don't worry, non-hubcentric spacers were always out of the question
djs801
Performance
10-27-20 09:45 PM
trinituner
10-10-13 01:12 PM
Jzsicklexi
07-20-12 06:05 PM
LilMan23
02-09-11 02:28 PM
sincityIS
Suspension and Brakes
12
02-19-08 04:33 PM
Quick Reply: Curious to know - a wheel spacer question
