Bridgestone RE960 A/S for IS350?
I really would like to get these tires for my IS350, but they don't make the correct sizes. Yet, I've seen multiple posts of members here who have these tires on their 350s. What sizes are people using to fit the 350 wheels?
assuming you have the staggered 18" setup from the factory, 225/40-18 / 255/40-18, you need to keep about an inch diameter difference front to rear...
the only RE960 combo I can come up with in 18" that I see available would be if some slightly larger sizes would be acceptable and fit... Might wanna check with some other 2IS owners to find out for fitment (or search here)
But anyways, 275/40-18 rear and 245/40-18 front... both are 20mm wider and .7" diameter bigger than what you currently have... they fit on the wheels just fine (a little bulky), I just don't know if they fit (they should)
