Is it possible to convert bolt pattern 5x112 --to--> 5x114.3 (fit on 2GS) ?
Old 09-24-07, 12:14 PM
masboy
masboy's Avatar
Default Is it possible to convert bolt pattern 5x112 --to--> 5x114.3 (fit on 2GS) ?
i really like this wheels for my 2Gs, but the bolt pattern is 5x112 would it be possible to convert it to 5x114.3 ? thx
Old 09-24-07, 12:43 PM
VM 2
VM 2's Avatar
Maybe if you can find someone ti redrill the rims
Old 09-24-07, 12:44 PM
tam4G63
tam4G63's Avatar
if the 5/112 wheel is drilled at 14mm (bolt hole), it would fit. But keep in mind that it wont be center and would cause wheel vibrations. So I would not recommend it. Move on to another wheel.
Old 09-24-07, 02:53 PM
masboy
masboy's Avatar
aggh damn it....alright, i guess i have to move on...
thanks!
Old 09-24-07, 03:41 PM
DCMango
DCMango's Avatar
5X112 WILL fit your GS. You will need to use tuner lugs and make sure you get a good set of hub centric rings.
Old 09-24-07, 04:18 PM
excluesive
excluesive's Avatar
no need to redrill?
Old 09-24-07, 04:24 PM
masboy
masboy's Avatar
for real, that's it ?? no re-drill ?? has anybody use 5x112 in their Lexus ?
Old 09-24-07, 04:39 PM
DCMango
DCMango's Avatar
You do not need to RE-DRILL! I am running Lowenhart LSR 5X112s on my 98 GS300, all you have to use are 'stepped' or 'tuner' lugnuts in order for the application to work!
Old 09-24-07, 04:42 PM
DCMango
DCMango's Avatar
Here's proof -
Old 09-24-07, 04:43 PM
benxd
benxd's Avatar
European wheel fitment (5x120) wouldn't work though right?
Old 09-24-07, 04:46 PM
DCMango
DCMango's Avatar
No, that will NOT work.
Old 09-24-07, 04:54 PM
masboy
masboy's Avatar
cool. Thanks DCMango!
Old 09-24-07, 04:56 PM
excluesive
excluesive's Avatar
this is definitely going to open a few doors to me
THANKS DC
the gs looks sick too
Old 09-24-07, 05:09 PM
DCMango
DCMango's Avatar
No problem guys! Just a heads up, as mentioned in my earlier post, you need to get a set of hubcentric rings. This is a must for all Lexus vehicles anyways, so for those that have aftermarket rims, you should already have them. For the most part, I have not had any problems, but with the tuner/stepped lugs, there will be a little play, play around with it a little to get rid of the vibrations.
Old 09-24-07, 05:33 PM
FIVEOHinNJ
FIVEOHinNJ's Avatar
Holy ******! I did not know this was even possible! If anyone wants, I can put them in touch with a guy who knows of a shop in Ca that re-drills bolt patterns on rims for $100/per rim.
Quick Reply: Is it possible to convert bolt pattern 5x112 --to--> 5x114.3 (fit on 2GS) ?
