Opinion Falken FK452 Tires 245/40ZR19 on 19x10R pls
guys, i need wheel/tire expert to tell me if it's OK to get this tire : Falken FK452 Tires 245/40ZR19 for my 19x10R rims ? I'm planning to drop it 1.5".
I was searching around and seems like most people prefer to use 270/30 for their 19" rims. Any different with 245/40 ?
Thanks!
The only reason you'd want to go with a 245 on 10" width rim is to run a stretched set-up to accommodate a really aggressive fitment.
a 245 is a significant stretch and i sure as hell wouldn't do it, though its quite possible some on here have done it for wheel fitment purposes. a 255 is occassional, and you're definitely right that a 275/30 or 285/25 is very common due to proper width and sidewall/circumference
the drop isn't significant, so why such a thin tire on a wide wheel?
Why falkens? There are better tires. I prefer Nitto 555. Falkens side walls split on me, on 2 tires and wear fast. Nitto also has a better rim protector and better looking sidewall.IMO
