problem: cant get lugnut off
Old 10-08-07, 10:13 PM
lighthalo
lighthalo's Avatar
Default problem: cant get lugnut off
so i was going to take my wheel off to mess with my brakes, the first lugnut i pick to loosen, i start turning it and it takes a while to get loose. then i jacked the car up and removed all of the lugnuts except this one, it wont come off. it seems like the lug nut is sitting at the end (or near the end) of the threading because it wiggles around just like it is about to come off but it is stuck, maybe the threading (on the bolt or just on the lugnut) is messed up? can some one help me get this off? any suggestions?
ive tried tightening it again and then loosening it but it seems like it wont go anywhere. like it just rotates in place or something.
Old 10-08-07, 10:37 PM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
Attach a pole to it....and HIT IT down as hard as you can....it will surely come off...
Old 10-09-07, 08:39 PM
lighthalo
lighthalo's Avatar
oh it turns but it just dosent go anywhere.. do you mean just try to break it off? lol.. i could give that a try haha
Old 10-09-07, 09:23 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
yes, once it gets that bad, it will need to be broken or cut off...
however, what I would do to start...
get the car on a jackstand, make sure it is secure... take all the lug nuts off except the offending one... rotate the wheel so it is at the bottom... now, take something like a 2x4 (to protect the wheel), and a sledge (I prefer a 5 pounder), and hit the backside of the wheel (the 2x4 really) and this should hopefully be enough to coerce the lug nut off.... a 8' 2x4 stretched underneath the car will be long enough if you don't feel comfortable reaching under the car to mash on this thing... (on a longer stretch, a larger sledge will probably be needed)
Old 10-10-07, 11:26 PM
lighthalo
lighthalo's Avatar
so i tried that today and its still not comming off... maybe im not hitting it hard enough?
any other methods?
i tried sawing with a blade but i cant move worth crap under my rim...
JSwenis
IS - 1st Gen (2001-2005)
08-09-10 08:41 PM
gman44116
12-12-09 10:05 AM
np20412
11-06-06 01:08 PM
UptownGS
07-09-05 02:46 PM
TMaxxTim
Suspension and Brakes
14
04-02-05 11:34 PM
Quick Reply: problem: cant get lugnut off
