Tires sizes for AWD?
Old 10-13-07, 01:25 PM
9520G
9520G's Avatar
Default Tires sizes for AWD?
I have a 95 eagle talon tsi AWD, I have rims that are 20x9.5 and 20x10.5 with a -7 offset. What tire sizes do I use so the overall diameter is the same since its awd?
Old 10-13-07, 03:47 PM
qttire1
qttire1's Avatar
this website might help out
www.sizeitup.com
Old 10-13-07, 04:07 PM
9520G
9520G's Avatar
That is a nice website but its not functioning too well.
Old 10-14-07, 01:17 PM
mitsuguy
Maintenance Moderator
mitsuguy's Avatar
you don't... even an 1/8th of an inch in difference will tear out the viscous coupling, or tear up driveshafts if you are running a spool... you need to have the same size tire all around...
I have seen this phenomenon in real life, and bought a car off a guy that had destroyed the diff due to it...
Old 10-14-07, 04:57 PM
9520G
9520G's Avatar
So can I put 245 all around even though the front is 20x9.5 and the rear is 20x10.5?
Old 10-14-07, 10:45 PM
mitsuguy
mitsuguy's Avatar
it'll be stretched a lot, but yah...
I have one question... what widebody kit do you have? DSM's aren't exactly known for fitting wide wheels front or rear... hell, I had 255's on 8" wide wheels +35 offset, and they rubbed the fenders on the rear... you are wanting to stick a wheel almost 3" farther outside than that...
Old 10-14-07, 10:48 PM
9520G
9520G's Avatar
The rims are actually off a widebody 350z, I test fitted the rims and they fit perfect. Itd the GT3 widebody and its extremely wide. Here is the pic of the rear wheel on the car.
Old 10-14-07, 10:50 PM
9520G
9520G's Avatar
I was also doing research and found that even though I put the same size tire on all four rims the OD will change because itd different size rims. Any truth to that?
Old 10-14-07, 10:54 PM
mitsuguy
mitsuguy's Avatar
nope,none at all...
the steel belt (radial) of the tire is, well, steel, and will not change diameter no matter what...
not a bad setup on that car, however I think I'd go wider than 245's if there is enough room... 265's, maybe 275's...
Old 10-14-07, 10:58 PM
9520G
9520G's Avatar
Thats what I'll probably end up doing and want to do but I'll have to widen the front fender just a few mm. The front rim was maybe 4mm wider then the fender. Thanks for all your help!
Old 10-16-07, 04:59 PM
9520G
9520G's Avatar
Well I have been doing some research and the best tire size combo I found so far is 265/25/R20. The OD difference is only 0.34 inch difference. What do you think? Can you think of a better combo.
Old 10-16-07, 09:13 PM
mitsuguy
mitsuguy's Avatar
sounds like a pretty reasonable size to me...
Old 10-16-07, 09:15 PM
9520G
9520G's Avatar
I just spoke with Mr.Mark and he said I can also run 235-30-20 and 265-25-20 and he said the OD is still pretty close to stock.
blaraf10
11-02-14 03:50 PM
andyboy
06-29-10 07:54 PM
midnite23
04-27-09 03:52 PM
otee670
08-29-08 07:10 AM
Burst32
03-07-07 08:25 PM
Quick Reply: Tires sizes for AWD?
