GX470 tire fitment
Old 10-16-07, 07:52 PM
GXlexus470
GXlexus470's Avatar
Default GX470 tire fitment
Can someone please advise if this will fit GX without tire rubbing problems:
Wheel: 20 X 8.5 6X5.5 +18 (size, bolt pattern, Offset)
Tire: 275/45/20 (conservative)
285/50/20 (aggressive?)
295/50/20 (pushing?)
305/50/20 (...?)
I'd like to go 285 or 295 but wasn't too sure. 305 might have problem so might not even go there. 275 is too OEM like... I think? Any suggestion? Thanks.
How about offsets... does too much negative offset messes up suspension or has undesirable outcome? say for the GX: 0 to -18 offset?
I have an 03 GX470 standard (no tmps). Thanks.
Old 10-18-07, 08:42 PM
qttire1
qttire1's Avatar
285 will look right, also your offset is correct +18, to much negative offset will push the wheel out and with the 285 it will rub.
check out www.sizeitup.com for tire & wheel fitment info, this site has all the info your looking for
Old 10-19-07, 09:33 AM
GXlexus470
GXlexus470's Avatar
Thanks qttire1 for the input... that site was great! Thanks for sharing.
Old 10-24-07, 06:48 AM
qttire1
qttire1's Avatar
glad i could help
Old 10-24-07, 08:05 AM
GXlexus470
GXlexus470's Avatar
bud, do you know if increased or decreased overall wheel diameter ie, using lower profile tires, will damage transmission or other related parts. I know that the odometer will either go faster or slower. www.1010tires.com shows comparison between tires and also suggests not to exceed 3% in overall diameter otherwise you would run into potential braking power loss. That's about what I could research on the net... but damaging trans... that's new. This Discount Tire tech guy is insisting on a 265/50/20 because bigger diameter might damage my trans... I wanted to go at least 275/45/20 or even push it to 285/50/20 on a 20X9 +18mm offset. Any suggestions?
Old 10-30-07, 07:39 AM
GXlexus470
GXlexus470's Avatar
qttire, thanks so much for your info/input. i'd like to share you what i got on this thread. i liked how it turn out... check it out.
https://www.clublexus.com/forums/sho...d.php?t=312472
gn87
01-13-15 06:21 PM
papak
RX - 3rd Gen (2010-2015)
08-01-13 02:18 PM
Tdvlexo
02-13-10 08:20 AM
SorrGwa
03-24-08 07:22 PM
alxmorse
07-28-05 12:53 AM
Quick Reply: GX470 tire fitment
